Apple AirPod Pro tips and tricks
Quote from adouglas on 03.05.2022, 19:27I have a pair of Apple AirPod Pros. If you've considered these and Googled you'll probably find some videos and reviews that aren't positive.
I've had good success because of a few simple steps I take:
1) Get some silicone ear hooks. I have these: https://www.amazon.com/Proof-Labs-AirPods-Covers-Compatible/dp/B0844WPDY5/ref=sr_1_3?crid=1Z3TF3PB9W7WY&keywords=apple%2Bairpods%2Bpro%2Bsilicone%2Bear%2Bhooks&qid=1651623644&sprefix=apple%2Bairpods%2Bpro%2Bsilicone%2Bear%2Bhooks%2Caps%2C44&sr=8-3&th=1 They keep the AirPods in place nicely.
2) Wear a balaclava. I've always done this anyway to keep my helmet from getting gross but it comes in handy when it comes to earbuds... having your ears covered will keep the AirPods in your ears when you put on your helmet.
3) Use the noise canceling feature and experiment with different ear tips. I find the noise canceling to be very effective and the earbuds are quite comfortable.
4) When you stop for a break, put the earbuds back in their case for a quick top-up on the charge. The batteries will only last about 3-4 hours but they charge fast. Simply staying ahead of it ensures you won't go flat and lose your noise canceling.
5) Carry a pair of earplugs in your pocket just in case.
With these few things done, I'm 100% satisfied with them.
Quote from Jarhead on 25.06.2023, 19:26I use my AirPod Pro’s all the time when riding, I also use a silicone ear hooks if its a windy or it’s going to be a rough ride but often without the ear hooks when just riding around town. If you get the version with the best sound cancelation the music and ride will be pristine. Here in Missouri (US) we aren’t required to wear a helmet and I typically don’t on my Spyder F3 Limited so the premium sound and low external noise makes for a great listening environment. I tried some cheaper ear pods, none compare to the AirPods.
Quote from msprygada on 13.07.2023, 20:49I have not idea how you guys wear ear buds under your helmet. There is no way I could get my Air Pods Pro under my helmet. Makes me wonder if you have your helmet sized correctly.
Quote from Jarhead on 13.07.2023, 20:56Getting a properly sized helmet is simple—don’t wear one, that’s pretty obvious if you read the posts…
