Forum breadcrumbs - You are here:Scenic ForumScenic Feature RequestsAdventure mode
Adventure mode
Hi Guido
I’m more and more getting into mixing on and off-road routes when riding. Works great when I have an gpx file but making a route is quite the opposite. Is there any chance on implementing an adventure kind of parameter that focuses on off road? Stegra IO had a feature like that where you can swap on the fly. Would be a great addition to the nav app.
greets Corné.
LaszloK
Everything is possible, but this requires our map provider to add routing options. This won't be for a short-term thing.
Hmm, well, ok. Shame it’s not on the current radar, I can imagine that, with the rising popularity of the ADV segment, this would be a very popular addition to the app.
Adventure Mode is pretty handy once you get used to it. I’d try it with a shorter route first and see how it handles the roads around you. Checking the route before starting is also worth doing, since the suggested path can sometimes be a bit more adventurous than expected.
Quote from SabrielaHong on 27.08.2026, 01:16
Can you explain what you mean here?  I'm pretty sure Guido just said "Adventure Mode," as described by @cornworld, is not an available navigation option, and probably wouldn't be for some time...
Cornworld has reacted to this post.
Cornworld
I think you have curvy and beauty setting in mind here. That’s not what I meant. I’m talking about the option to create off road routes like DMD2 and Stegra, they have an adventure routing build in.
Scenic excels in creating curvy routes but lacks, for the moment, in off road capability. Unless you manually create one or adjust an existing one.
@sabrielahong, can you add a screenshot what you mean with adventure mode? (use the add media button). Thanks
Maybe she means "Avontuurlijk" which you can choose by shifting the bar if you select "Voorkeur wegtype" which you can choose if you choose Route Type "Standaard".
I'm am interested to know the difference between this and the "Curvy" Route type since it creates longer routes than the curvy option.
I'm currently planning a route to Romania next week and I'm not sure which option created the most beautiful route.
