Adding a Stop to an existing route in carplay whilst riding
Hi all,
First time posting
I was riding along a simple route (going home) on apple carplay and I needed fuel. So I went through the menu, search, Fuel, found a service station and chose to add it as a stop.
It displayed in the overview, but as soon as I started riding again, it totally ignored the fuel stop and continued to the destination. I then kept trying it with different routes (simple or complex, fuel or POI etc).
Behaviour was always the same, as soon as I started moving, it ignored the stop and continued on as if I had not added a stop.
Is there a step I missed? or is it a bug?
Thanks!
Karimero has reacted to this post.
Karimero
typically I start a new direct route to the gas station and afterward re-start original route but I have tested what you wrote I have the same issue……no way to get that to my route.
It does not help but at least you are not the only one,
Thomas
Thanks guys. Have a fix ready for next beta build. If it works, will deploy to App Store soon.
thank you, but today I tried that again and it did work now. Not sure what the reason was but I tried first on my Ipad and it did not work, today on my Iphone it worked and now after another test with the Ipad it worked as well.
Thomas
@middelfrangge. That version with fix was not released to the App Store yet. Are you on the beta test? What version are you running (bottom of settings)?
thats why I was confused when I tested today again without an update. I am not a beta tester and I use 4.47 version.
Thomas
I tested it again yesterday on a long ride and it was consistent, it discarded the waypoint unless I chose to do a new route and then restart my original route. I am also using version 4.47 but only tried it on carplay.
I’ve just tried this, adding a searched for fuel stop to an active route using CarPlay  (4.48 beta 2 which has the fix) and I can confirm it works.
Guido and Lifetimerider have reacted to this post.
GuidoLifetimerider
Tested it with the new just released V4.48 and it worked!
Thanks Guido!!
