Release Notes Scenic iOS
VERSION 4.47 — 2026-10-21
– Fix for dark navigation arrows on dark background on CarPlay when in dark mode.
– Reduced size of next turn arrow on CarPlay a bit, so that the panel covers less of the map.
– Revamped “Discover routes” feature and added “best first” sorting, making it easier to find better quality public routes.
– UI adjustments for basic iPhone Duo support
VERSION 4.46 — 2026-10-10
– Simplified planner UI with respect to adding vias and stops to a route.
– Solved appearance problem on CarPlay dark appearance where turn arrows and grid menu icons had dark color on dark background
– Route sharing enhancements
– Fix for the GPX export of a track only containing start and end point.
– Fix misaligned accuracy circle for current position indicator
– Some translation improvements
VERSION 4.45 — 2026-09-28
New features:
– If a calculated routes has unpaved, toll or ferry stretches, a message is displayed about that below the route length and duration. Those stretches will also have a different color in the route. In Settings > Appearance and colors you can change those colors or turn this off.
– Updated route sharing to match the recently added folder sharing feature (protect route from further distribution and give users view or edit access)
– Added feature to get (and print) a list of “written directions” for a route
– Brought back direction arrows in the route
Fixes / Enhancements:
– Fix for sometimes entire route being skipped for round trips and detour behaviour set to “Don’t recalculate”
– Fix for trip estimate panel not readable on CarPlay with iOS27
– Fixed an unwanted move of the Home screen bottom buttons after keyboard used in other screens
– In areas not supported by beauty routing, route calculation now falls back to curvy routing in stead of standard
– Fixed a bug in the show route full screen view, where disabling “show vias” still left some via points on the map.
– Improved the track simplification algorithm which should make imported tracks, round trips and curvy+beauty routes match better.
– Fix for current location position not updating while in Overview/Edit mode during navigation
– Fix for reordering waypoints in the route timeline sometimes not working (dragged row snaps back)
– Fix for vias sometimes not being marked as reached and map sometimes turning when reaching a via.
– Stability improvements
VERSION 4.44 — 2026-08-30
– Improved via and stop placement during planning (added long-press and double tap actions and made the explanation of the options more clear)
– Now given choice to add search result as any kind of waypoint
– Fixed bug where search result callout was not moved to location of crosshair
– Improved visibility of planner help button
– Fixed ‘Repair Sync’ not working for accounts with lots of data
– Stops will now be marked as reached sooner, even if stop is not reached exactly
– Stops can now also be auto-skipped if auto-skip setting is enabled in ‘Detour Behaviour’
– Revamped Offer Store
– Route Folder Sharing (under ‘Actions’ button in Route Folder header view)
VERSION 4.43 — 2026-08-08
We ship new features, improvements, and fixes regularly. Keep auto-update on so you never miss what’s next. Here’s what’s new in this release:
NEW FEATURES:
– Home Screen and Planner UI design update
– Default rerouting behaviour now more as generally expected:
– Less strict in considering a waypoint as reached (you don’t have to get as close to it)
– Added a ‘Skip Radius’ for auto-skipping via points (only via points in the skip radius will be automatically skipped)
– Default behaviour is now auto-skip waypoint within skip radius after 3 recalculations
– Added setting to switch to shorter verbal instructions (Settings > Sound & Voice Instruction)
– Added options to delete search term history and recent destinations
BUG FIXES:
– Decreased possibility of route taking offramp only to take onramp again
– Fix for color picker being unresponsive when saving a new location by long-pressing on the map
– On CarPlay the icons in the focussed (selected) map button were not readable
– Some voice instruction changes for Hungarian
– Fix for sometimes not being able to scroll all the way up again on iPad in My Routes/My Rides/My Locations.
– Fix for temporarily not having guidance instruction (visual and audible) after transferring navigation to CarPlay
– Fix for unreached waypoints being greyed out after editing a route during navigation
– Fix for old, already reached, waypoints being reinstated after editing a route during navigation
– Fix for map being stuck at certain rotation angle (not rotating with riding direction) after transferring to CarPlay after editing a route during navigation
– Folder count sometimes wrapping number to 2 lines if it goes into 3 digits
– Debug menu section is now revealed above the version number
– Fix for changes to an existing route sometimes not being saved persistently
– Fix for road closures and traffic incidents not showing on the map
– Doubled character limit for Ride descriptions from 2000 to 4000
– Fix for “Guide back to route” button not working on CarPlay
– Fix for ‘sticky’ route name when importing several routes from a single GPX sequentially
VERSION 4.42 — 2026-07-14
– Improved import for GPX files with certain format
– Improved compatibility for “Saving blue line as track”
– Made syncing between devices more reliable
– Added ‘Repair Sync’ feature in debug menu
VERSION 4.41 — 2026-06-23
– Emergency fix for curvy route generation in North America crashing the app
– Fix for battery saver screen not disabling when approaching a speed camera
VERSION 4.40 — 2026-06-18
– Fix for curvy routing sometimes giving “out of bounds” error message in Australia
– Fix for danger zone warnings (speed cams) in France not disappearing after exiting the zone
– Changed alphabetic sorting so that “Day 10” follows “Day 9” in stead of “Day 1”.
– Fixed minimum zoom level for Lvl 6 and Lvl 7 roads
– Fix for map stuck in north-up on CarPlay after editing a route during navigation
VERSION 4.39 — 2026-06-08
VERSION 4.38 — 2026-06-03
VERSION 4.37 — 2026-05-20
– Fix for vehicle picker resetting to top scroll position in the save ride view.
– Fix for thumbnail not refreshing after changing the position of a location from the ‘My Locations’ list
– Some language copy updates
VERSION 4.36 — 2026-05-03
– Fix for some lakes, reservoirs and other types of areas not showing on the map (re-save your custom map styles for it to take effect)
– Fix for “save” button being covered by keyboard while saving a location during navigation
– When editing a stop name the newly entered stop name is now auto-capitalized
– Fixed marker icon for red-light safety camera
– Fix for current time and battery level sometimes not updating in Navigation landscape view
VERSION 4.35 — 2026-04-18
– Fix for some users getting “can’t edit route because you are not the owner” message even though they are the owner
– Fix for map losing tracking and heading-up after editing route during navigation while on CarPlay
– Fix for ‘road closures and incidents’ enabled setting not being remembered sometimes.
– Fix for calculated route line covering street names.
– Fix for calculated route line being covered by recorded rides layer.
VERSION 4.34 — 2026-04-09
– Color of crosshair in planner can now be customized.
– Added marker appearance settings for safety cameras.
– Fix for road closure and incident markers sometimes not showing when moving/zooming to a new map area.
– Land area of islands not being drawn at zoom levels below 13 for custom map styles.
– Removed zoom limit for zoom out button during navigation
VERSION 4.33 — 2026-03-28
– Fix for red turn instruction background on CarPlay on iOS26.4
– Fix for “I have an offer code” button not working on iOS26.4
– Fix for sometimes not showing info bubble when tapping an incident icon
– Fix for incorrect ride duration and avg speed when scenic is killed during a ride and ride is resumed on CarPlay (without opening Scenic on iPhone)
– Fix for close button of subscription screen hidden behind status bar on iPhone SE.
– Fix for incident icon size setting not being applied on CarPlay.
– Fix for island land areas sometimes showing as water
– Fix for not being able to hide keyboard when entering a route review.
VERSION 4.32 — 2026-03-16
4.32 release notes
– NEW FEATURE: Road Closures & Traffic Incidents (https://scenic.app/help/closures-and-incidents/)
– Folder header view not pinned to the top anymore in landscape mode, leaving more space to see routes/rides/locations in the folder.
– When adding a stop during navigation on CarPlay, search results can now be shown on the map
– Added pagination for CarPlay systems that limit the number of rows in a list
– Disabled auto-correct in search term entry
– Final turn instruction at low speeds comes a bit sooner now
– Font color for personal POI labels now depends on map appearance to give it more contrast.
– Fix for map sometimes getting stuck in northUp after a disconnect/connect from CarPlay
– Fix for ride start time being reset when resuming a ride after Scenic closed during navigation
– Fix for Speed+Turn zoom level “stuck” after a turn when speed stays constant.
– Fix for not searching with Apple when tapping entry from Search term History
– Fix for thumbnail images sometimes not persisting when satellite maps are enabled
– Fix for “done” button disappearing on add new location screen after opening marker editor
– Fix for quick search results not being tappable on some CarPlay units
VERSION 4.31 — 2026-02-28
We are continuously working on adding new features to our app, optimizing existing features, and fixing any potential errors.
4.31 release notes:
– Turn based zoom enhancement… now zooms in earlier before the turn
– Fix for speed based and speed+turn zoom not working when just tracking
– Fix for still auto-resuming after choosing “Pause ride GPS OFF”
– Fix for forcing 2D mode after switching to other app on CarPlay
– Added feature to regenerate map thumbnails
– Search result sorting based on relevance rather than distance.
– Fix for Google Search not always returning results
– Fix for map scale being incorrect in CarPlay
– Scale is now hidden in 3D mode, because it’s not meaningful there
– Fix for Scenic not responding to HandlebarController input after starting music playback
– Fix for HandlebarController not zooming in/out in ‘Manual + Turn’ zoom.
– Fix for forest color sometimes being applied to water areas.
– Fix for deleted/moved elements in layers still appearing on the map.
– Fix for not being able to choose a custom color in Settings > Appearance & Colors
– Increased RV routing distance limit to 10.000km for offline maps
– Added special offer for Carpuride CarPlay units
VERSION 4.30 — 2026-02-20
4.30 change log:
– Added additional zoom mode (Manual with turn assist). More info here: https://scenic.app/help/zoom-modes.
– Improvements to search
– Improvement to zoom on CarPlay
– Fix for tap on compass not turning map
– Fix for subscription options showing twice sometimes
– Fix for MapScale inaccuracy
– Added option to show zoom level in MapScale label
– Moved ‘special offers’ to side menu
– Added option to enable/disable startup sound
– Changed default route color
– Fix for RV routing ignoring vehicle size/weight restrictions
VERSION 4.29 — 2026-02-11
Version 4.29 brings bug fixes and improvements.
Safety Cameras Expansion:
– Expanded safety cam coverage to world
– Country-Specific Safety Camera Settings
– Ability to hide the safety camera setting, disable or completely remove the safety camera feature
– Shows average speed while in an average speed section
– Warnings show a bit earlier now
More info here: https://scenic.app/help/safety-cameras
Safety cameras bugfixes:
– Camera markers sometimes not showing on CarPlay map
– Reduced warnings for cameras on parallel roads
– Warning sometimes covering map scale, compass, elevation indicators.
– Warning sound did not always play
Other:
– Solved bug with map scale when mi,yd selected as unit
– Added setting to increase speedometer and speed limit size
VERSION 4.28 — 2026-01-08
Version 4.28 brings SPEED CAMERAS, and some minor bug fixes:
– If compass is disabled, elevation is partially dropping off the screen on CarPlay.
– Vehicle pictures not syncing
– Occasional crashes when editing routes through the route timeline list
– When adding route to tracking session, and then changing the route (reversing) Scenic never recognizes when you reach the route
– When avoid unpaved is enabled, and a via point is placed that can only be reached through an unpaved road, the route calculation ‘hangs” (spinner keeps showing)
VERSION 4.27 — 2025-12-11
TAKE THE SCENIC ROUTE – Plan, ride, track, and share your adventures with the 4th major iteration of Scenic.
Version 4.27 addresses some bugs and brings stability and performance improvements.
Bugs fixed:
– When adding a route during a tracking session Navigation doesn’t start (‘Go to route’ remains on screen)
– If route has via points, the route timeline shows incorrect arrival time and distance for stops.
– Handlebar controller “Overview” shortcut while on CarPlay brings map into a state that user can’t get out of
– On CarPlay, when on manual zoom mode and returning from overview (panning) mode, the map doesn’t zoom back to level it was before going to overview mode.
– Crashes when editing routes through the route timeline list
– Riding time and riding duration are not updated after a route was added during a tracking session
New features:
– Setting to log raw location in stead of snapped location
VERSION 4.26 — 2025-10-31
TAKE THE SCENIC ROUTE – Plan, ride, track, and share your adventures with the all-new 4th major iteration of Scenic.
Version 4.26 addresses some iOS26 UI issues and solves a bug where route start was sometimes name ‘Route End’ after an edit.
VERSION 4.25 — 2025-10-26
Bugs fixed in 4.25
– Scenic not continuing to track after adding a route during tracking session.
– Unexpected behaviour after editing a route during navigation and then reconnecting to CarPlay
– Crash on Mac when opening native color picker
– Error message output is rerouted to CarPlay even when working on the phone itself
– Crash when deleting waypoints during a stop, and then reconnecting to CarPlay
– When selecting a track to navigate on iPhone, and then switching to CarPlay, the track is no longer displayed.
– White screen on CarPlay after disconnect and reconnect while Scenic was in split screen
– iPhone screen doesn’t sleep when connected to CarPlay
– Can’t get out of panning mode on CarPlay with just Joystick
– Unexpected deviations from main roads with RV routing.
– Route/Ride share links don’t open in Facebook Messenger
– When staring navigation of a pre-saved route, the route custom color was overruled by the route default color.
New in 4.25
– Moving of map with touch now possible on CarPlay
– Added setting to prevent auto-lock when connected to CarPlay
– Added current location to ‘Discover Routes” screen
VERSION 4.24 — 2025-09-05
New in v4.24:
– Ability to change routing mode on CarPlay
– Ability to add a stop during navigation on CarPlay
– Ability to select another route during navigation on CarPlay
– Ability to search POIs (including fuel stations) on CarPlay
– Cleaner default map styles
– Integration & Accessories section in Settings
– Integration with ‘Weather on the Way’ app
Bugs fixed in v4.24:
– Unable to duplicate default map styles
– Visual speeding warnings not showing on CarPlay
– Wrong vehicle icon in routing-mode-button when importing
– White compass on dark map in CarPlay
– iPhone screen does not auto-lock when connected to CarPlay
– Main view buttons still clickable while routing mode panel visible
VERSION 4.23 — 2025-08-20
New in v4.23:
– New default map styles
– New default tint colors
– Ferry lines now visible on map
– Automatically switch away from edit mode when user switches back to CarPlay
Bugs fixed in v4.23:
– Crash on iPads running iOS26 beta
– Photos taken in Scenic not being saved to photo library
– GPX files downloaded from a share link not containing latest route changes
– When route tracking paused, the route recalculation sound still plays
VERSION 4.22 — 2025-07-07
What’s fixed in version 4.22:
– Recorded rides outside your Favorites folder now load correctly after logging out and back in.
– Resolved occasional crashes when the “Do not auto close” option is enabled in Settings > Navigation & Tracking > Menu Auto Close Time.
– Improved alignment of the scale, compass, and elevation indicators on left-hand-drive CarPlay systems.
VERSION 4.21 — 2025-06-28
What’s New in Version 4.21
> Faster, smoother CarPlay map panning – Dragging the map on CarPlay now feels responsive and fluid.
> Accurate ride distance after crashes – Your total distance will continue from where you left off—even if the app unexpectedly closes or crashes.
> Instant breadcrumb trails – See your route path immediately when you start a ride.
> Reliable map-follow on CarPlay – The map will lock back onto your real-time position a few seconds after you stop panning it.
> Correct centering in iPhone landscape – When starting a navigation, your location marker is now positioned towards the lower-right instead of dead center.
> Compass and elevation visible on CarPlay – The Compass and elevation are no longer hidden behind turn instructions on right-hand-drive CarPlay displays.
> Tidy route lines in overview mode – The route line thickness is now just right, so your path is easy to follow.
> Consistent RV units – RV dimensions and weight settings save correctly—no more mixed metric/imperial glitches.
> Fewer unexpected crashes – Under-the-hood fixes to prevent occasional app crashes.
VERSION 4.20 — 2025-06-12
Version 4.20 solves a crash in the onboarding flow
Version 4.19 squashed some pesky bugs and brought a handful of useful enhancements to improve your Scenic experience.
Bug Fixes
– Fixed crash when reconnecting to CarPlay after disconnecting
– Resolved issue where curvy routing sometimes created illogical legs and detours
– Toolbar buttons disappearing and right-side elements misaligned after CarPlay reconnect
– Changes to routes, rides, locations, and POIs now update correctly in map layers without needing a restart
– Roadblock feature now works reliably
– Route line too thin in 3D mode
– Fixed crash when saving a ride after Scenic was unexpectedly quit
– Resolved sporadic crashes during navigation after skipping a via point or changing the route
– Fixed occasional crash when saving a “just tracking” ride
– Resume ride alert now correctly appears on CarPlay when reconnecting with a paused ride
– Previous route’s waypoint markers no longer persist on CarPlay after starting a new route
– Route line no longer lingers on CarPlay after finishing a ride
– Startup crash fixed for some users on iOS 18.5
– Resolved issue where the screen could freeze when starting a route on iPhone and then connecting to CarPlay
– Waypoints now render correctly above location markers in the layers panel
– Color changes in Settings > Colors & Appearance now apply as expected
Enhancements
– Navigating tracks now available on CarPlay
– “Guide Me to Route” button now available on CarPlay
– New setting to “Prefer Local Language” for city names and POIs on the map
– “Guide Me to Route” now takes you to the closest waypoint instead of the first unreached one
– Added setting to prevent auto-closing of menus during navigation
– Option added to download satellite maps only when connected to Wi-Fi
Map Customizer Fixes & Enhancements
– Railways now display properly in custom map styles
– Fixed duplicate “Cinema” entry in POIs > Entertainment
– POIs > Natural > Volcanos now correctly shows volcanos, not mountain peaks
– Mountain passes now appear in custom map styles
– Private parking lots no longer appear in custom styles
– New option to allow/disallow overlapping POI icons
– Fixed issue where building colors were overridden by residential area colors in some combinations
– Building names, addresses and house numbers not responding to font size changes
VERSION 4.19 — 2025-06-11
Version 4.19 squashes some pesky bugs and brings a handful of useful enhancements to improve your Scenic experience.
Bug Fixes
Enhancements
