Zooming in on the map while creating a new route
I am fairly new to Scenic. I am enjoying it so far but I can't seem to figure out how to zoom in on the map while creating a new route?
Can someone help me with this??
Simply pinch with two fingers. Or, if you are on a Mac, hold command key down and then scroll up or down.
Does that answer your question, or am I misunderstanding?
Thank you very much. Yes this worked. I could swear I tried that a dozen times...
Next question:
I have turned on POI’s and Gas stations and so forth. How do I get them to appear on the map while creating a rout?
In the "show on map" panel (3rd button from top left in main screen), make sure to set the checkmark also in the "while planning" column. Also, make sure you have the latest Scenic version 3.63 (there was a bug in an earlier version). You can see version number in the bottom of settings. Here's the direct link to the app store: https://apps.apple.com/app/id1089668246
