Forum breadcrumbs - You are here:Scenic ForumUsing ScenicZoom zoom
Zoom zoom
Is it me or does the zoom function not zoom in as close as it used to?
Max has reacted to this post.
Max
Didn’t change anything regarding that. Maybe in 3D mode it requires some adjustment. You can configure it a bit in Settings > Finetuning > Zoom customization.
Hello Guido
I've a comparable feedback on v4.09 : after fine tuning the "automatic zoom with speed", I happened to use from 19 (max zoom in at low speed) to 18 at speed above 140 km/h .
Tuning range is 2-19, only using 18-19, 17 showing 5/10 km ahead at last extremity (for german free-speed autobahn )... "2" shows the continent map, not using a jet every day 😉
When using the "manual mode",  max zoom-in appears to be around somehow something like 20 in comparison, very usefull,  but no available in automatic mode .
-> could it be possible to enlarge the "automatic mode" tuning range to 20,  same level as "manual" mode ?
BR
Thks in adavnce for understanding and reply
Yes... I can increase the max zoom level to 20 for the zoom configuration. Will do that for the next update.
Fred_Moto25 has reacted to this post.
Fred_Moto25
