Wunderlinq und Scenic
Quote from Halifax on 26.05.2020, 09:54@guidomm
Hallo Guido,
ich habe seit heute den Wunderlinq, und wollte ihn gleich mit Scenic ausprobieren, doch leider kann ich aus der Scenic App nichts mit dem Wunderrad meiner GS machen. Weder kann ich raus- noch reinzoomen geschweige dass ich die Starttaste auf dem Navibildschirm mit der gesperrten Tastenfunktion drücken kann. Was mache ich falsch?
Danke für deine Hilfe.
Hallo Guido,
Quote from Guido on 26.05.2020, 10:08Haben Sie 'Ich habe einen WunderLINQ' in den Einstellungen eingeschaltet?
Quote from Guido on 26.05.2020, 13:32OK. I just added a support article, including video on how it should work. Could you have a look at that please? https://scenic.app/scenic-unterstutzung/wunderlinq-integration/
If this doesn't help, could you check if the WunderLINQ works with WunderLINQ's own app? If it does not, it is not a Scenic problem, but rather a problem with the WunderLINQ or the connection.
Quote from Halifax on 27.05.2020, 05:59Hi Guido, I saw the video and recognized that I didn’t have the orange frame around the start button. I also have a problem with the Wunderlinq BT connection, sometimes it works sometimes not. So I guess the problem is more on the hardware site. I tried to contact Blackbox Embedded. First of all thanks for your quick response.
Jörg
Jörg
Quote from Guido on 27.05.2020, 06:12Ok. Could be a hardware issue indeed. Also note that WunderLINQ doesn’t work with older BMW models. For example, I believe it only works on the models that can control the Navi Unit with the wheel.
The best check is to see if it works with the WinderLINQ app itself. If it does it should also work with Scenic. If it doesn’t then there is a problem.
Good luck... I hope you find the problem and will be able to get it fixed / replaced.
Quote from Halifax on 27.05.2020, 10:05The wheel works fine with the N5. I also could go through the Wunderlinq App but the data’s I get are really strange:
