Forum breadcrumbs - You are here:Scenic ForumUsing ScenicWunderLINQ
WunderLINQ
sorry if this has been addressed before, I did search but couldn’t find anything. It’s looking like I can’t use the WunderLINQ at the moment, that is the main reason I use scenic, when will that feature be back?
WunderLINQ should work. Tested myself (not with the WunderLINQ but the MotiveMonkey), and have confirmation of  another WunderLINQ user that it works.
Try toggling the “I have a remote” switch off and on,  in settings > handlebar controller
In the Scenic main/start screen you can only select the “Ride” button (should have border around it when WunderLINQ connects). You can’t move to other buttons. So… if you press and hold to the right it should go to “navigation” mode. In navigation mode you can select the navigation menu and move around. The shortcuts should work in both screens.
It works if I open it separately but if I select navigation from the WunderLINQ app I get this message.
Follow the steps. Then iOS should know that you allow this, and Scenic should open without this message.
  1. If I press and hold I get this message, what steps are you referring to?
Hmm. That’s a bug I think. It should offer you to open Scenic. I’ll look into it.
greg2112 has reacted to this post.
greg2112
Quote from Guido on 05.10.2024, 07:15
Hi Guido I've the same issue with starting Scenic from the Wunderlinq device (since version 4, version 3 was working fine)
same screens as shown in #5 from GB
Thanks for the big efforts you already realized, hope this issue can be solved on a short notice.
will be solved in v4.01 (release by end of this week)
I am having problems with integration as well. I have handle bar control set in Scenic. I have Scenic set as my navigation in WunderLINQ. When I am in Scenic and long left press my wonder wheel, then WunderLINQ opens. However, when I try to use navatigation from WunderLINQ it gives my the webpage to tap and hold for scenic. It does go back to scenic. When i shift over to AppleMaps as the option, the integration works. But i really prefer to use Scenic! 🙂
I moved Scenic to a new developer account which caused this. I made some changes, but it can take upto a week for them to take effect (has to do with caching on Apple servers). You can speed up this process by removing Scenic from your device and reinstalling through the App Store. This has the disadvantage that you'll need to re-download your offline maps, and reconfigure your settings the way they like.
So… either:
1) Wait a week or so. It will start working eventually, or
2) Remove Scenic from your device and reinstall through the App Store.
