Written Directions
Quote from Elric42 on 04.12.2025, 18:06Since the group I organize drives for requires written instructions, does anyone have any suggestions on how to easily make written instructions from route in Scenic?
Right now, I have to do it manually, recreating the route in Google Maps. It takes a really long time.
Thanks!
Elric42
Thanks!
Elric42
Quote from Guido on 04.12.2025, 20:39Scenic currently doesn’t generate the turn instructions in advance. One way to make this (a bit) more efficient is first create the route in Google Maps and then import that (by copy pasting the Google Maps url) into Scenic. Here’s a quick tutorial video on that: https://scenic.app/help/import-from-google-maps/?seq_no=2
Quote from Elric42 on 05.12.2025, 08:31Guido,
When the route is simpler, this works very well. Most of the time, I have Scenic generate the route for me, which it does fantastically well.
Maybe there is an app or something that makes written directions from gpx files? Or, maybe a future feature?
Thanks for a great app!
Elric42
Guido,
Elric42
Quote from jmossfeld on 26.12.2025, 21:59RideWithGPS can generate a cue sheet from a route. The app generates turn cues and you can also add your own custom cues. The app then lets you see a cue sheet with the distance to each cue from the start. A cue sheet is a great paper backup in case your electronics fail.
