When will Scenic be usefull again, like in 3.5?
Quote from Zipfi on 19.04.2025, 13:47By the last 3 trips, all around 500km, I‘m really disappointed about the performance of Scenic 4.
The map design is way overloaded, a map designer is urgent needed. But the main problems are the not working zoom and the delayed map follow with the position arrow. Often you are already at the turn point, but zoom not shows on map an position arrow is behind your position.
These problems are exactly identical on two bikes…
I tried KURVIGER today on a long ride, no zooming errors and the position arrow was everytime on point.
so when will Scenic be back on track?
Quote from Guido on 19.04.2025, 13:57Map customizer is coming soon. Beta of this feature starts on Monday/Tuesday.
Zoom is very personal. Have you tried adjusting the zoom levels in Settings > Finetuning > Zoom configuration?
Position lag: there is currently a performance problem that’s causing this. Looking at this as we speak. What helps is to completely close Scenic before starting a new navigation session. And you can try to enable “extrapolate position” in Settings > Finetuning (if not already done so)
Quote from Zipfi on 19.04.2025, 14:08Zooming is on app default, I can‘t understand why the default is not useable. Personal adjustment is nice, but not from a bot working default.
extrapolate ist already active.
it‘s really sad how scenic actual performs, it‘s almost may, far away from october 2024
i think i will quit my scenic usage for know and will check again end of season 25, maybe
Quote from Guido on 19.04.2025, 14:11I’m personally happy with the default zoom settings (that’s why I made them the default). What would you like to see different? I can try and adjust somewhat. Are you using Scenic on iPhone or CarPlay? Are you using 3D mode or 2D mode? (these have influence on the zoom behaviour).
Quote from Guido on 19.04.2025, 14:12Oh… and are you using speed based zoom or turn based zoom?
Quote from Zipfi on 19.04.2025, 14:21I used scenic on carplay in 3d, default zoom. Tried speed and turn based, both not working.
the default zoom is too close. When i use Kurviger, i can see the next turn with a distance of 650m, in scenic I an see the next turn with a distance of 50m and with the position lag I‘m mostly already behind the turnpoint.
I‘m really sorry Guido, but in no Navigation App I every used, I had to costumize the zooming.. this is a basic feature what needs to work
Quote from Maneno on 22.04.2025, 04:02Hello Guido,
I have been using Scenis for a while (since V2), but always in my motorbike.
Few weeks ago I did a trip of around 2000 km in a place where I had no connection, so I decided to sownload maps in Scenic and use it for the first time in a car.
IDuring around 10 days I rented 2 different cars, both with CarPlay, and I realized that Zoom behavior is different from one CarPlay to the other. After suffering from a "too close" zoom problem in the first Car, I adjusted the Zoom to around 15 for low speed and everything went mujch better.
Behavior in the second rented car was slightly different, so I adjusted the settings again. But when I came back to my motorbike the zoom was extremely far.
I am quite sure you're aware of this, but sharing it anyway in case it is useful for you or other Scenic users.
In 1 month I am starting a 6000 km moto trip using Scenic 4, so it will be a nice test for the app...
Hello Guido,
Quote from Zipfi on 22.04.2025, 05:50That is really interesting Maneno!
I just did a short drive in my car (Mercedes) with Scenic and new custom zoom settings. This worked really well! So I‘m curious if my motorcycle Carplay makes the same good job or do the same strange thinks like you mentioned….
Quote from Guido on 22.04.2025, 08:16Hi @zipfi, @maneno,
If I’m not mistaken, Zipfi is running the latest beta version 4.18(3), correct? That beta contains an adjustment for the zoom behaviour. (Sorry… I didn’t mention that in the beta release notes). That probably explains the different behaviour you are seeing.
Quote from Zipfi on 24.04.2025, 22:59Yesterday I tried my new zoom settings, that works well in my car, on my bike.
Same behaviour, it worked good. I‘m still confused why the sandard settings are so bad, but ok, now this is solved. The last things that I recognized are the bit laggy position arrow and the wrong distance post on screen. Scenic tells left in 450m on the highway to exit it and I was only 100m away from the turn point.
Quote from Maneno on 25.04.2025, 02:40Hello @zipfi,
I believe Guido mentioned that this arrow positioning delay is due to a performance issue being analyzed.
Thx
D
Hello @zipfi,
Thx
D
