"what3words" support
Quote from sebastos on 08.03.2021, 18:46Hello!
Looking forward to Scenic 3.0! Have already signed up for the beta, would appreciate if you have one spot left.
Would it be possible to add "what3words" support to Scenic 3.0?
It is a really helpful addition to share a location with others, as it is so much easier than GPS coordinates. I have seen that Kurviger.de supports it and Triumph has it now added to their Speed Triple 1200 navigation.
Sebastian
Hello!
Sebastian
Quote from Guido on 08.03.2021, 18:52I'll add it to the list. Thanks for the suggestion. Probably won't make it from the start, but a bit later in the year
Quote from sebastos on 08.03.2021, 18:54Wow! That was a blazing fast answer!
Thanks very much!
Looking forward switching over from Calimoto to Scenic, now just the weather needs to get warmer in Austria again.....
Thanks very much!
Quote from PatB on 11.08.2022, 09:53Is this still in the pipeline?
I think this will be an increasingly useful feature to have as what3words is only going to grow 🙂
Quote from Guido on 11.08.2022, 10:17Still in the pipeline, but not a priority item at the moment. Sorry.
Quote from mbirth on 07.11.2022, 19:32Quote from sebastos on 08.03.2021, 18:46It is a really helpful addition to share a location with others, as it is so much easier than GPS coordinates. I have seen that Kurviger.de supports it and Triumph has it now added to their Speed Triple 1200 navigation.
What's wrong with sharing the w3w address from the dedicated w3w app?
And to get a w3w-code into Scenic, you can look it up in the w3w app and then share the latitude/longitude (needs to be configured in w3w settings first) to the clipboard and use that in Scenic.
