Weather on the way App integration
Great job Guido! The weather on the app integration adds so much functionality to Scenic!  Thanks
Guido, DRTBYK and MjK have reacted to this post.
GuidoDRTBYKMjK
Guido,
I'm on the road in Sicily and have been using Scenic most of the past month on iOS26. Things have been working well but two days ago I installed Weather on the Way and connected it to Scenic. I have the Pro version on my iPadOS26 iPadPro and the Free version on my iOS26 iPhone 16Pro Max. Both integrations worked once. Now when I send the Scenic GPX file to Weather on the Way, Weather on the Way crashes on both iOS and iPadOS. I tested with a few other GPX files of Tracks from Furkot and they all worked fine in Weather on the Way.
Any ideas?
UPDATE(#1):
It seems that it is just one of my planned rides that is causing WOTW to crash. Attached is the GPX export from Scenic - which crashes WOTW.
20250917_161627_day-19---thursday-18-sept-2025
UPDATE(#2):
It seems that WOTW does not like it when there is a STOP waypoint and an END POINT at the same location. I removed STOP#2 and WOTW no longer crashes.
Dan T. - on the road in Sicily, IT
Hi Dan... do you know that Weather on the Way now integrates with Scenic directly? At least for your routes (not recorded rides). Simply select the route from your route list > 3 dots button top right > Weather on the Way. Does it also crash if you use it like that?
@MjK has put a more specific post about the integration in the Scenic users Facebook group: https://www.facebook.com/share/p/19w9nwBsHD/?
I have been using the Scenic Integration with WOTW. See my post above for the issue that WOTW can't handle from Scenic.
Dan T.
OK. I wrongly derived from your message you were still using the GPX export and then "open in" panel.
Anyway... I have forwarded the GPX to WOTW. They should be able to tell me why it crashes... and then we'll figure out where the problem is (Scenic or WTOW), and fix accordingly.
DRTBYK has reacted to this post.
DRTBYK
Hi folks,
looking for the Wotw App in the store. Cant find it. Maybe its a translation issue. Could someone be so kind to post the picture of the app?
Thanks, Mex
Maybe i found it:
Translation in German:
Wetter entlang der Route.
Just in case someone is searching.
9 bucks / week
30 bucks / year
Regards, Mex
Not it. This is the correct app…
[caption id="attachment_9641" align="alignnone" width="313"] Screenshot[/caption]
Marco1971 has reacted to this post.
Marco1971
In Scenic, go to Settings > Integration & Accessories (towards the bottom). There you will find WOTW. The button will take you to it’s app store page.
Marco1971
Thanks guys.
Found it. Give it a try on my next ride.
Regards, Mex
Quote from DRTBYK on 17.09.2025, 08:48
Guido,
Any ideas?
UPDATE(#1):
UPDATE(#2):
@drtbyk. Hi Dan, WOTW is releasing an update in the next few days with a fix for this. Cheers, Guido
Quote from Guido on 23.09.2025, 10:01
Guido,
Any ideas?
UPDATE(#1):
UPDATE(#2):
@drtbyk - the fix v2.2.6 just got released today - just tested your file and it works now
This seems like a great integration to get weather updates.  I haven't tried it yet since I haven't paid for WOTW.   When I send my route to WOTW, who's doing the guidance?  WOTW or Scenic?
