WEATHER INTEGRATION
Quote from blackhawk1618 on 08.05.2024, 03:22I must say your efforts are commendable for making Scenic an ultimate choice app for motorcycle enthusiasts like me or others out there.
I would like to see weather integration in the Scenic app which would be a significant enhancement for keeping track of weather conditions during rides, particularly on long rides across different terrains.
I don't mean to sound buggy, but I understand that weather integration has been a topic of discussion for many years now. Do you have any updates on when it will be on your top list for development, and is there any promising timeline? 🙂
Quote from Guido on 08.05.2024, 09:20It's on the feature request list, but I just need to find and make time for this. No timeline 🙂.
Quote from Michel on 19.05.2024, 10:45Would like to add that Calimoto has just this spring removed this feature, which I used a lot with the Garmins I used up to recently. I saved me from getting wet more than once…
Quote from GHJ on 20.05.2024, 00:42I'm looking for an alternative for the moment. Does anyone know a suitable weather app that also runs on carplay?
Quote from Karlchen on 20.05.2024, 03:49Anscheinend läuft diese App mit CarPlay.
Das habe ich aber nicht getestet.
https://www.google.com/search?q=wetter+app+carplay&rlz=1CDGOYI_enDE1111&oq=wetter+app+carplay&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTExMDU5ajBqN6gCALACAeIDBBgBIF8&hl=de&sourceid=chrome-mobile&ie=UTF-8
Viel Spaß beim Testen
Quote from GHJ on 20.05.2024, 04:25Thanks, just what I was looking for.
MyRadar works on CarPlay.
Quote from W1ldBill on 17.08.2024, 08:45https://apps.apple.com/ca/app/weather-on-the-way/id1471394318
Does a decent job, no carplay integration, nice way to plan for weather & departure times.
Quote from mattsz on 17.08.2024, 09:33Quote from W1ldBill on 17.08.2024, 08:45https://apps.apple.com/ca/app/weather-on-the-way/id1471394318
Your app store link shows a picture of it being used on carplay... maybe not in the way you want it, though?
Quote from masupert on 19.08.2024, 12:23Quote from GHJ on 20.05.2024, 00:42I'm looking for an alternative for the moment. Does anyone know a suitable weather app that also runs on carplay?
MyRadar Pro
MyRadar Pro
Quote from BrAtKo on 20.08.2024, 04:43I would write some notices from me. MyRadar is not available in the Slovak app store (I think there will be more countries where it's unavailable). And the app Weather on the way is quite expensive, the best weather app Windy is not carplay compatible.
Quote from Karlchen on 04.05.2025, 01:07Hallo Guido,
ich weiß, die letzten Monate war mit viel Arbeit verbunden.
Aber gibt es zum Thema Wetterdaten auf der Tour inzwischen einen Zeitplan.
Beste Grüße
Hallo Guido,
Beste Grüße
Quote from MjK on 05.05.2025, 03:36Hi,
I am using both „MyRadar Pro" as well as „OnTheWay" since quite a while on the iPhone as well as on CarPlay.
In general to be present on CarPlay any weather app needs to have some kind of navigation integrated - otherwise Apple does not allow the CarPlay function to be used and rejects the AppStore presents of the app, hence why there are not so many apps out there.
- MyRadar
- has a beautiful moving radar screen on the iPhone showing a short history to current of cloud / weather movement - this movement also indicates the direction the weather is developing
- unfortunately this movement is not reflected on the CarPlay screen, there it just shows the last current cloud state.
- Same for an weather alarm for the current region you are in - works on the iPhone, push does not go through to CarPlay
- OnTheWay
- does not have any movement on the radar, but indicates the direction by showing arrows on the map.
- It does have a much nicer and cleaner radar screen and is super accurate.
- A key benefit is the import of a Scenic GPX file. OnTheWay will calculate the estimated time of arrival at the stops along the route and provides a nice overview whats the weather like at the time you will arrive, very handy.
- You even can define a 7 day advance departure time - it will help finding the best time to ride by dynamically show the respective weather scenario along the route.
- Routes can be saved for future use
- Using Scenic as the main navigation app, OnTheWay navigation could be activated in the background, so whenever the weather screen is activated (iphone as well as CarPlay) OnTheWay is on your spot and can help not only with the radar screen, but as well with the timeline of the remaining route what’s to be expected ahead.
- A group guide can also easily share those timelines to help everyone be prepared.
Personally I prefer OnTheWay over MyRadar in the meantime and I just would love a better/smoother integration between Scenic and OnTheWay, like simpler route sharing or more advanced, based on OnTheWay weather conditions, a re-route suggestion by Scenic ...
I know this is not a priority and many may not need it, but using both apps in parallel does not kill the battery (iPhone location service leveraged by multiple apps is minimal battery impact) but kept me pretty dry - especially in the mountains just re-routing to another valley keeps the rain away. But an integrated way preferably weather provided by Scenic itself or with one click on a second screen, would not only provide more important information for a ride, but increase the safety tremendous
just my 2 cents, Markus
CarPlay Radar Screen MyRadar
CarPlay radar screen OnTheWay
OnTheWay iPhone screens and push notification
- MyRadar
- OnTheWay
Quote from MjK on 05.05.2025, 08:21Quote from Karlchen on 05.05.2025, 04:32Dankeschön für die Info
@karlchen - just one more info, as it’s a nice way using both apps at the same time - if you have both devices (CarPlay + iPhone) insight at the same time - not necessarily on the bike, rather in the car :
while you run scenic on the CarPlay display, switch the black scenic screen to the OnTheRoad app - when you have loaded there the same route, you see the naming of the different spots as well as expected arrival time (matches pretty much the time scenic is calculating) and highlevel wether. By tapping a spot on the iPhone you want to know more the gray popup shows even more details.
This does not directly help yet to identify a reroute, but is super helpful if at all something needs to be considered.
but how much cooler would it be if similar weather info with an weather overlay on top of Scenic would be reality - definitely something to top up the premium subscription
Quote from Karlchen on 05.05.2025, 08:31Ich habe die App bereits installiert und wer der in Juni auf meiner Urlaubsreise die 7 Tage testen. ny Radar ist raus gefällt mir nicht. Die andere sieht sehr interessant aus.
nochmal dicken fetten Dank dafür 👍🤘👌
Quote from BMWMark on 09.05.2025, 15:15Quote from GHJ on 20.05.2024, 00:42I'm looking for an alternative for the moment. Does anyone know a suitable weather app that also runs on carplay?
MyRadar App runs on CarPlay. Think you have to have premium subscription @ $30 per year. Works pretty well on CarPlay screen.
Quote from sdk on 14.05.2025, 23:24Not for carplay, but I'm a fan of: https://www.epicrideweather.com
