Forum breadcrumbs - You are here:Scenic ForumUsing ScenicWay points Moving
Way points Moving
Hey there
Using Scenic on a recent run it kept trying to divert me as way points which had previously appeared accurately on the map, once underway, were off the map. I had to continuously skip way points to continue on my planned route. Was running the latest version of Scenic (as of four weeks ago).
hasn't happened to me previously...
Hi Andy,
That's a weird one. If you select this route from your route list, and then choose "Edit Points", are the waypoints at the correct place?
Hey Guido
Thanks for the quick response. In edit form, the way points are perfect - even when I zoom right in to ensure they're right.
Hi Andy,
Would you mind sharing this route with me? (select route from your route list and tap the 'share' button). If you'd rather not share it here, you can send me a direct email using the email button at the bottom of the help page.
How far (in meters or feet) did the waypoints move more or less? Did they move further along the route, or did they move with a result that the route was different?
