Warning when approaching a POI
Firstly I must commend you on the Scenic app improvements, I’ve been using it daily and am suitably impressed.
A feature request that I would gratefully welcome would be a “warning” when approaching a POI.
For example, I have a POI library of mobile speed camera sites in the UK, I have uploaded them into Scenic and assigned images for them - great that I can do that. However if I’m not looking at my navigation unit I sometimes miss the POI’s.
would it be possible to have a warning Sound (a bleep or similar) that sounds as I approach it ? It could be as simple as a tick box item within the POI screen where you can set them to appear.
Hopefully you could implement this.
kind regards,
martin.
CuttingIron, satmax and Marts have reacted to this post.
CuttingIronsatmaxMarts
Adding proximity alerts for POIs is on the list, but will take a while.
First, I'm going to add back the built-in speed cameras that Scenic 3 had. That will already solve the most important use-case for POI proximity alerts.
I'd like to bring this one up again. The option to get an acoustic warning when approaching an user-created POI always came in quite handy when it was still available in older versions. It is not exclusively about speed cameras, but also about landmarks, gas stations, restaurants I approach and do not want to miss on a longer tour. I remember to have used that feature on almost every ride when it was still available in the older versions of scenic, not only when following a pre-planned tour but also when just recording the ride (and yes, this one is about speed cams...;.).
Thanks and cheers
Peter
I understand. It's still on the list, but currently higher priorities require my attention. Hope you understand.
