Voice volume
Quote from Atticuscat on 23.06.2025, 07:07Is it possible to add some more fine-tuning of the guidance voice volume? I find ‘normal’ a bit too quiet but ‘louder’ too loud. I could really do with something in between. (Using English UK Daniel. Tried Arthur but his pronunciation is too often unclear and Martha often slurs and distorts like she’s just finished a bottle of tequila.) Would be nice if the English UK pronunciation was actually UK (not just the accent) but I suspect this is out of Scenic’s control.
Quote from Guido on 23.06.2025, 13:01I'll add it to the list. Will be a while though as there are currently many items with higher priority on the list.
I assume that you are talking about the voice volume relative to the music volume, correct? If you are not playing music through your phone, then you can just adjust volume of the voice instructions with the volume buttons in the navigation menu (the big button menu).
Also, if you are using a headset, check if that has some settings to change the volume of voice instructions relative to other volumes.
Quote from Atticuscat on 23.06.2025, 14:37Yes, with music playing, so the Scenic instructions are either quieter or louder than the general music. I use in ear monitors that connect to phone or CarPlay (depending on which motorcycle I’m using) with no settings other than standard pause/play/skip buttons (which I can’t access anyway because they’re inside my jacket).
Thank you.
Thank you.
