Via point numbers not updating after route edit
Love Scenic. A small thing (bug) I’ve noticed a few times recently is that if I decide to shorten a route that I’m already navigating by deleting some upcoming via points, that Scenic will update (correctly) the upcoming via point numbers on the map, but any messages that come up while navigating still refer to the original via point numbers instead of the new ones. (E.G., if a via point was number 45 in the original route and I delete some preceding points, it could now become via #29 on the map. This is correct. When I eventually get there the navigation messages will refer to it as via#45, even though it shows correctly on the map as #29).
A small annoyance, but can be a little confusing as we’re not yet able to see far enough ahead on the route sometimes (another topic that we’ve discussed before - it would be nice to have a setting that allows for zoom customization on different speed roads for different distances 😉).
Still loving Scenic.
Mark
Edit: I forgot to specify that this is using Scenic with no data connection on downloaded maps, which is the only way I use it in the US.
Hi Mark,
I was actually aware of this one. I’m working on a big update at the moment where the entire navigation code is renewed. Will make sure this big is resolved there too.
Cheers and thanks,
Mark has reacted to this post.
Mark
