Forum breadcrumbs - You are here:Scenic ForumUsing ScenicV4.20 CarPlay no map
The issue where no map is displayed when starting Scenic still persists. Usually, switching to windowed mode and then back to fullscreen resolves it. On one occasion, even that didn’t work — only a CarPlay restart helped.
Hmmm. I'll look into it. Could you remind me of your setup again? Wired CarPlay or wireless?
Scenic running on iPhone before you connect to CarPlay, or not?
At this time I use Carpuride, wireless and a iPhone max pro 16. Same problem was on a Scenic <4.18 and wireless CarPlay on a Honda Africa Twin.
In both cases I used offline maps.
