Forum breadcrumbs - You are here:Scenic ForumUsing ScenicUsing Scenic in Landscape
I have just purchased Scenic and so far I am very pleased with it. However I have come across an issue. I like to use scenic in landscape mode when I am navigating. I found the option within the scenic menu to 'lock orientation'  I have an iPhone 12 Pro Max, running IOS 16. When I start navigation, I ensure that the iPhone is not locked in portrait mode (via the top right pulldown menu), then when I turn the phone into landscape mode, Scenic also changes to landscape mode. All good so far. In order to keep scenic in landscape, I select the menu, and then the 'lock orientation' button. I see a message saying 'Orientation Locked'. If I then turn the iPhone back towards portrait mode, the navigation display flicks between portrait and landscape constantly (about every half a second). The only way to stop it is to switch off the iPhone and restart it. Is this a known bug, and is there a workaround?
Russell
Hi Russel,
more users have reported this issue. I’m looking into it and hope to bring out an update with a fix by end of next week.
best regards,
guido
Thanks guido
