Using Scenic horizontal view
Hello Guido,
When using Scenic in horizontal view in. the phone I have a few questions.
I am new at Scenic and trying to discover how it works
So, when navigating is there anything on Settings that says the distance to nearest Via Point? There should be a warning.
this is what it looks like
As I am new using Scenic and I know you are too busy I will leave these comments for now.
Best regards
In Scenic 4 you do not get distances to via points. You do get distances to stops. You can see them by tapping the area where you see the arrival time. If you want you can also choose to permanently see arrival at the next stop: Settings > Navigation & Tracking > Show time and distance to.
Thank you for the quick reply. Understood.
And what about the two speed that appears? One do not work. When in vertical only appears one.
Is another problem with my settings?
Tomorrow I'm releasing an update which will fix that.
Thank you.
Start enjoying it.
