Forum breadcrumbs - You are here:Scenic ForumUsing ScenicUsing import via Webapp
I tried to use the import function of the Webapplicaties. Unfortunately it will not work, I've done many attempts on different days. I used this in the past (months ago).
What can be the issue ?
that time it worked fine. What can be the issue ? (See at)
What file type are you trying to import? Can you send it to me? (use the ‘email me’ button at the bottom of https://scenic.app/help )
