Urgent planning help needed
I’m currently planning routes the Europe for a tour in a few weeks. I’m using a combination of google maps and basecamp where I am saving the gpx file and send the gpx file to my phone and saving that in my files and opening it with scenic which works on the whole ok. But I’m also using google maps, I copy the the link into the box but when I open it in scenic the route has changed, why is this?
Could you check if you are using the latest Scenic version 3.63 (at the bottom of settings). If you don’t have 3.63, update through the App Store: https://apps.apple.com/app/id1089668246
If that doesn’t solve the import problem, could you send me the Google maps URL so I can try myself ?
Latest version Guido, will send link later as not new my Mac at the moment.
Hi @gb,
After some analyses, it turns out there is a bug in Scenic. Scenic is not taking over the routing options you set in Goolge (avoid highways, avoid tolls). Unfortunately, an app update is required to solve this. I’ll fix this for the next update. Meanwhile, until then, I recommend either (1) during import, add the avoidances manually (tap the routing button in the top toolbar) and/or (2) add via points to make the magenta line match the blue dotted line.
Sorry for the inconvenience, and best regards,
