Ups, Scenic deletes the roundtrip
Scenic does not work on a round trip.
I'm starting Scenic,
I would like to go on a round trip,
I choose from the S/W direction,
Length 150km,
curved route,
Scenic generates the winding route.
Okay, I start the navigation,
Motorbike is running, I put on my gloves
and suddenly Scenic deletes the route!?!
I try again and again and again,
The tour is always deleted after a maximum of 3 seconds.
Last attempt, the tour is completely generated on the screen and waiting for "Start",
but this time I start the motorbike first and while I'm rolling I start the navigation
and now suddenly everything works!
The problem can be repeated at any time.
That is not okay.
Thanks for the feedback. My theory is that Scenic thinks you arrived at the end, while you are just getting started. I'll have a look at that for Scenic 4 (october 1st).
I've seen this too and deduced the same as you Guido. So I entered the start and finish points at different, but close to each other, locations.
That's right.
But it is your own roundtrip
and not a roundtrip generated by Scenic.
mattsz has reacted to this post.
mattsz
