Guido on 07.07.2025, 02:23
Hi @jth,
At the moment Scenic doesn't have real time road closure information integrated. I'm planning to add that this calendar year.
You could indeed check against Apple Maps or Google Maps.
Scenic does have a "road block" feature that enables you to indicate if you run into a blocked road during a navigation session. Scenic will then try to find a way around the blocked roads that you indicate.
Hi @jth,
