Unpaved Road Warning
Quote from AKAsam on 05.10.2022, 08:06I keep getting a warning that says " The Route was calculated but avoiding Unpaved Roads could not be honored" It would be great if the map would identify where the unpaved road is that way I can edit the map to go around it. BTW i did try changing the color of unpaved roads to see if I can find it, with no avail.
Quote from Guido on 05.10.2022, 09:05Yeah. I understand. Problem is that the road colors are covered by the route, so you don't see it. I'm migrating Scenic to the new HERE framework during fall/winter, and will see if I can improve this / indicate the offroad stretches better.
If you get this with every route, perhaps it's a stretch very close to your starting point (your home). E.g. if you live on a unpaved road, and you always need to take this road (there's no paved way), then you will always get this warning. Only solution for this is to place starting point on the first paved section.
Quote from AKAsam on 05.10.2022, 09:53By the way, This App is amazing. You all made something truly amazing. I feel like a side walk preacher every time I talk to other motorcyclist, I always bring up the app and end up showing them all the features.
