unnötige Fahranweisung
Quote from Hein_38 on 15.06.2025, 05:11Hallo Guido,
habe folgendes festgestellt (V4.20) :
Route von MRA importiert und in Scenic teilweise nachbearbeitet.
Es wird bei jedem Via die Fahranweisung "bitte rechts halten" (bzw. "bitte links halten") gegeben. Die Vias liegen genau auf der Mitte der Straße.
Grüße Heinrich
Hallo Guido,
Grüße Heinrich
Quote from Dae on 15.06.2025, 05:34@guidomm is aware of this and trying to see if the map provider can sort it. He posted about it recently and we’ve exchanged many emails on it.
Quote from windingroad38 on 23.06.2025, 04:33it’s not only on via points. There are a lot, no, a huge mass of annoying and unuseful navigation announcements. I took some passes in the alps and there were so many many announcements on almost any serpentine like „turn right to stay on …“
And it was at least three (!) for every serpentine: 600m, 300m and 50m before.
So, when the pass had like 30 serpentines, I got 90 useless anouncements…😳I don’t need this announcement which „guides“ me through every serpentine where it is obvious where to steer…
Quote from Guido on 23.06.2025, 12:55@windingroad38... do you still have this route saved by any chance? If so, could you share it with me? (select route from route list > 3 dots button top right > share link). I'd like to see what instructions are generated. I might be able to filter some of them out.
Meanwhile there are 2 workarounds:
- Temporarily put sound to "alerst only" while you are gong through the hairpin corners (serpintines). Here's how: https://scenic.app/help/sound-voice-problems/ (number 3).
- Disable some of the voice instructions. Settings > Sound & Voice Instructions > Voice Instruction Frequency.
Quote from windingroad38 on 23.06.2025, 14:19Sure, here it is:
https://scenicapp.space/route/iyaYGszP
I really can’t remember exactly, there were so many curves. But I think I remember those anouncements after Via Point 7, for example. But I am rather sure this happened on the other roads likewise.
Sure, here it is:
Quote from TheDriver79 on 24.06.2025, 07:00I‘ve also reported this behavior with the small difference it does not happen for every waypoint but some and even after app. 4000km driven using scenic this year already I wasn‘t able to identify the differences in the waypoints that cause the direction announcements.
Still I‘m sometimes getting confused but mostly I am able to live with it. 😄
