Forum breadcrumbs - You are here:Scenic ForumUsing ScenicUnable to edit route
Hi, I created a route which looked good at the time, saved it, but now when I try to edit it, it gives an error "Route Calculation Error: No path could be found for input".  Before I click on Edit Route, the overview looks fine, and if I click on the overview, I can zoom in and see all the waypoints connected correctly.
I've made the route public: https://scenicapp.space/route/jOxnoInh
With this error, I'm unable to open the route for editing.  I also get the same error if I try to navigate the route.
Any idea what's going on here?
I recreated the route. Same stops, same exact route. A lot less via points. Here it is: https://scenicapp.space/route/zucdrqgX
I assume you made this with Scenic 3? That would explain why it doesn't calculate with Scenic 4 as that uses different map data and different routing algorithm.
Hi @guidomm, that worked, thank you.  I have other routes part of this tour, which I can edit without any issues, but they to were created using the old maps, would I need to recreate these as well or the fact that they can be edited means they’ve transitioned to the new maps without any issues?
If they can be edited it means they can be calculated. So that’s good.
I suspect that in this specific route one of the vis points was causing the problems. Rather then to try and find that via point I recreated the route.
