Un-skip a via point?
Quote from Stresspuppy on 15.04.2024, 14:24On two recent rides something has happened and a via point is skipped and my route is completely redone to the following via point, which one might expect, however, I didn't purposefully skip those points. Is there a way to "un-skip" a point and make it valid again so the route goes back to what it was originally? In both cases I knew where I was going so I just went there but I constantly got re-routing messages until I was to the next via point that hadn't been skipped. It was a bit annoying.
Quote from Guido on 15.04.2024, 15:00You can't un-skip, but you can enable a setting so that Scenic asks you to confirm a via point skip.
You probably enabled auto-skip via points. Have a look at the detailed explanation of the detour behaviour settings, and what they do exactly.
https://scenic.app/help/detour-behaviour-scenic-v3-5-and-higher/
