Transport modus preset in power plan
Quote from GijsbertZijlstra on 07.12.2024, 15:10Using power plan and plan round route, always the default transportmodus is choosen.
by choosing different preset (e.g. default to curvy) the route will nearly change, which was definitely in scenic 3.
will this be solved in scenic 4, and will there come a setting that you can pin the transportmodus preset which is used for every new route?
thanks.
gijsbert
thanks.
gijsbert
Quote from Guido on 10.12.2024, 08:53Hi Gijsbert,
The round trip feature is provided by Kurviger.de and is only available for the motorcycle and car transportation mode at the moment. That’s why it reverts back to the default mode after the round trip is generated, and also why changing transportation mode after, has no to little effect (the via points stay the same).
I’ll try to make this a bit clearer in the user interface
Hi Gijsbert,
