Traffic integration
Hy Guido,
it would  be great if you can integrate the road-traffic in the map. If there is a road closed, the navigation should reroute to the next via or stop.
Axel
Hi Axel,
Thanks for the suggestion. It’s on the list to add traffic in the future. I don’t t have a specific date yet, but it’s high on the priority list.
best regards,
Deleted user has reacted to this post.
Deleted user
On HERE traffic maps in the browser, longer route closures are marked.
https://wego.here.com/?map=49.07385,9.5881,14,traffic
If it were possible to select the traffic map from HERE for planning or for checking the route in the app, that would be a great help already in the preparation. This makes it easier to plan your tour around the unknown closures.
So it works in „Navigation“ from MyRouteApp. The route calculation consider this, an take a alternative route. Also you can see if there is a lot of traffic on roads. They use also „HERE“.
do you have news about the integration of traffic in Scenic?
Greetings, Axel
Hi Guido, I’d also like to add my vote for live traffic info and rerouting.
My daughter uses the Waze app but it’s route planning capabilities are poor compared to Scenic. Waze does have the advantage that it crowd sources traffic info from both Apple and Android users so it is often more accurate than the native proprietary apps. I wonder if Waze provide an API to integrate with?
FYI; as a user I’d be prepared to pay an additional premium for the best live traffic feed available. ( I suspect companies like Waze monetise their traffic feed data and there is no point having dynamic traffic data if it is inaccurate or out of date ).
hoyo has reacted to this post.
hoyo
I’m migrating Scenic to the new HERE map framework this fall/winter. During the migration I’ll also be looking at speed cams and traffic. Not making any promises, but the possibilities of the new framework look very promising.
hoyo, Mikestouren and ipro have reacted to this post.
hoyoMikestourenipro
