Trackline in carplay mode do not show up
Hello,
i imported a tour as track only-gpx because its most of the time offroad and i don't want scenic to recalculate the route because its a totaly different route. i use the app via carplay on my crf1100 africa twin. the problem is the track doesn't show up as a line. i only see the track points. In the app on the phone the track and the tracking points show up. I looked up the settings for the track line, but there is no setting especialy for the carplay look of the track line. Is their a work around to get this to work?
Best regards Bremsbacke
Hmmm... This sounds like a bug. I'll have a look at it in the coming week. Thanks for pointing my attention to this.
First my apologies for break in to this post , but the problem Bremsbacke runs into is the same as mine. I have also a crf1100 with carplay.
On the phone Scenic shows the tracks on the map, also with navigation. But if i plugged the phone into the bike carplay starts up and after I open the Scenic app, all the tracks are gone. however the POI I selected are there on carplay screen.
In the past I had no issues with tracks onbeheerd Carplay.
This was fixed in v4.20 (or at least it should be).
Could you check if your Scenic is up to date? You can see version number at the bottom of settings. If not on 4.20, you can update through the App Store: https://apps.apple.com/app/id1089668246
hey Guido,
Thanks for the quick reply.
My version is up to date (4.20)
I found a temporarily solution to overcome this problem to select the track, in this case it was the TET Netherlands and hit on the button navigate. Then the track appeared in Carplay. The only downside of this is if you want to do 2sections on TET (“Drenthe loop”)you need to stop and load the next section in.
I found this fix on this forum, but it was easier the old way. I also slide the button on the iphone to share problems with developers so the next time maybe you got some data to work with.
There is another way with the new Userinterface.
1. Load all the gpx tracks in one folder in scenic. In my case favorites
2. Go to the overlay button. The Dropdown opens.
3. Scroll down. After the map mode options you can choose to overlay selected tracks permananty
4. In my example i have 3 sections of TET Poland in my routes>my favorites. Make sure „Visible while planing“ and „visible while riding“ is checked.
When you now press drive the track will be visible always. Also while planing and multiple sections at once.
best regards
Thanks for de info Bremsbacke, but the way you described is exact the way I always done it, and now it doesn’t.
I've tried to reproduce the problem (in the way that @bremsbacke explained), but for me the tracks always show. It doesn't matter if I start CarPlay first, or first start Scenic on iPhone. The tracks are there on the CarPlay screen.
Sorry to ask, but could you double check that:
1) The tracks are in the folder that is activated in the layers panel
2) The folder has the checkmark in the "visible while navigating" column. (On CarPlay this is the column that Scenic checks as on CarPlay you are always in 'navigation' mode).
Mmh ok,
maybe it is the carplay version/firmware version of your AT1100? I will drive my bike in a few days. I remember that i have had the same problem on my last trip after i updated scenic and this was the solution. Take me a little bit to find the dropdown in 30 degree C and sun. But maybe there is also another reason. 😅
I try to reconstruct the problem soon.
Thanks guys for the quick response,
This morning before work a fiddle around with my track’s and replace them out of the favorite folder and put only te TET 2 sections of te TET Netherlands back into the favorite folder Also I uncheck and check again the show in planning map and navigation map and guess what…. Now I can see the tracks I selected.
I find this confusing and I don’t why it does work now. I did everything the same as lasttime, but now it work.
Also I check the firmware of my Honda and it is version 3.6. I think it’s up to date.
For now thanks for help and the fast response. I hope the problems are solved
Bremsbacke has reacted to this post.
Bremsbacke
