Tracking stop while change routing
Quote from MacGyver on 04.04.2020, 16:45Hi Guido
When I‘m on a route and I want stop this routing to change to an other route, the tracking stops too.
is it posdible to change routes without stopping of tracking?sometimes I have different route stored and I start with first one and after a while I change to an other route.
I want tracking the whole ride I do, not in steps...
Hi Guido
Quote from Guido on 06.04.2020, 10:35Understand what you mean. I will add this to the list of feature requests. Thanks and best regards, Guido
Quote from JBrant on 27.04.2020, 08:28I think this is what I’m looking for as well. It was something I was able to do with the last version. My typical scenario is to put in the name of a town on the map, generate a curvy route to get there, and go. Once at that town, I pick a new destination, and repeat until I’m ready to head home. It’d be great to log the whole outing as a single ride, but the current format forces me to finish the ride at the end of each routing location.
Quote from Guido on 27.04.2020, 08:39Quote from JBrant on April 27, 2020, 08:28I think this is what I’m looking for as well. It was something I was able to do with the last version. My typical scenario is to put in the name of a town on the map, generate a curvy route to get there, and go. Once at that town, I pick a new destination, and repeat until I’m ready to head home. It’d be great to log the whole outing as a single ride, but the current format forces me to finish the ride at the end of each routing location.
You can't add whole routes during a navigation session, but you cán add locations to a running navigation session. Simply drag the map while in navigation mode... you'll got to edit mode. Now you can add locations, search for places or touch the map to where you want to go next... and add that point as a stop to the route.
Quote from JBrant on 27.04.2020, 08:42When I try doing that, I get the following error:
”You can’t edit Curvy Routes and Round Trips that were generated in the start screen.”
Quote from Guido on 27.04.2020, 08:46Quote from JBrant on April 27, 2020, 08:42When I try doing that, I get the following error:
”You can’t edit Curvy Routes and Round Trips that we’re generated in the start screen.”
Ah yes...that's true. This only works when selecting a route for navigation (a route you created / imported through the routes tab) and if you select a location in main screen but leave routing to short/fast/efficient.
btw. you can also create curvy routes and round trips through routes tab > create route. If you do it like that, save that route and then select it for navigation you will get the option to edit during navigation.
