Tracking after Update 3.55
Hey Guido,
I updated the app yesterday. Today first ride. I did. not change any settings in the app, use it with carplay.
During „Tracking“ the was no indikation for speed limit of the road and maybe because of it no overspeed warnung during the ride. In the settings everything was switched on, before the update it works.
During navigation a route there was an indication on visual/audio warnings.
Same here - Scenic 3.55, IOS 17.4
Maybe on more problem/fault:
During tracking I added a stop (now it works), in this case „home“.
There was a route to home, but no information about distance and arrival time on the display. Also no direction arrows for the next turn.
This is very strange.
So... if you want speed information on CarPlay... you have to tap the "Start Ride" button (top right in the toolbar) to go to tracking mode.
Also strange about no arrival info on the display. This was also CarPlay? I will investigate.
I confirm there is a problem with the speed camera warnings. Sorry about that. I will investigate further this week and bring out an update asap.
Have not been able to reproduce the problem regarding no direction arrows and ETA info yet. Will keep trying over the weekend.
Quote from Guido on 16.03.2024, 11:35
Start tracking was with the Button right top on carplay. But no indicator for speed limit of the road or audio/visual warning during going to fast. I am from germany, download the maps for offlline navigation. It worked before update 🙂
I hope for good weather tomorrow, then I will check once again the arrival time/distance and direction arrows with or without carplay. Today it was during ride with carplay.
Similar issue today with latest version
started app on phone and locked
connected to carplay
started tracking from main map screen in CarPlay
I had no speed limit information on screen and when I went to split screen I had the old issue of no current road name (and no speed limit), no speed camera warnings
stopped off for a bit. Used the camera on the phone. Set off again and still had the issue
However, I stopped again a bit later and this time when i stated again i had current road name AND speed limit AND speed camera warnings. Everything was working as it should.
only thing that did happen different is that during the second stop I a) paused the ride with gps off on the phone, b) quit the app by mistake then immediately reloaded and c) resumed the ride from the phone before connecting back you to the bike.
just in case it helps diagnosis.
Same again today.
So it seems if tracking starts from CarPlay, the current road, speed limit, speed camera etc fail.
But if tracking is started from phone, then connect to CarPlay all seems to work.
In case that info helps 🙂
I checked the same today again. Mobile phone connected to CarPlay, with cable. Start Tracking with the top Button Right, Tracking started, but no inication Speed Limit of the road, no warnings during overspeed.
Start Tracking without CarPlay on the mobile, there is an indication. Then Connect with CarPlay, it works.
It is not good to use.
I can confirm the second Problem from yesterday after test today.
I started Tracking with CarPlay. During the ride I added a stop (for example fuel, home) There was no guide to the stop. No voice, no arrows for turns, … empty display. Also no distance til the stop, no time of arrival. No function.
If I use the same during navigation a route, it works.
At the moment there are some problems in Scenic with the functions, which I prefer to use every day. I hope for good/fast solutions soon.
Working on it this week. Hoping to release an update with fix before the weekend.
Tested today morning... the bugs are fixed with 3.56... I am happy 🙂 For the moment it works very well...
Guido and Deleted user have reacted to this post.
GuidoDeleted user
