time error
Quote from georgefjr on 30.06.2020, 14:33hi just got scenic so just learning.
did a trial run in a car, got it to log my route, which it did, then converted it to a track, this showed the time as 15 hrs 26 mins, should be mins and seconds,
don’t understand the route did not follow my exact track, i had to adjust it
thanks
thanks
Quote from Guido on 30.06.2020, 15:37Could you send me screenshots of the ride and route please?
Quote from georgefjr on 02.07.2020, 03:43two screens, one the route, note the route, when i converted it gets it slightly wrong, so asks me to use the blue line, which i did then it was correct
Quote from Guido on 02.07.2020, 08:51Hi George,
Unfortunately I can't see the screenshots. I guess something went wrong with uploading. You can use the 'Add Media' button on the top left of the panel that appears to type your reply to this message.
The reasons why the route can be different from the actually ride can be many, but usually can easily be corrected. Have a look here for tips & tricks: https://scenic.app/knowledge-base/strange-loops-while-importing/ (this is about importing, but most of these things also apply to creating a route from a ride).
Then the timing issue... that really sounds like a bug. Would really need to see the screenshot on that for me to investigate further.
Thanks & regards,
Hi George,
Thanks & regards,
Quote from georgefjr on 02.07.2020, 16:50
hi sorry got it wrong
just uploaded 4 screenshots, 2 as a route, that were converted to tracks, note the difference between time in routes and tracks
probably operator error, help! lol
Quote from Guido on 02.07.2020, 16:58Nope...that's not operating error. That's a bug. I'll look into it for the next update. Thanks for the screenshots! Very helpful!!
