Time calculation and unpaved roads
It just occurred to me, that Scenic 4.16 has some serious issues with the estimated duration of travel times - when it comes to unpaved roads. Just made made a route with the curvy algorithm, about 90 km, with the last third probably on unpaved roads and it reads over seven hours! Kurviger - for comparison - estimated something around 1:45 h for the same route.
Unpaved stretch between vias 14 and 27
Guido has stated that a fix for this is in the pipeline  and should be here soon
https://scenic.app/forum/topic/scenic-wildly-over-estimates-duration-of-rides/#postid-11577
Jan has reacted to this post.
Jan
yes. This has been an issue since 4.00. Working with the map provider on a solution. If it was only in my control the solution would already be here.
johansw and Jan have reacted to this post.
johanswJan
Thank you and keep up the great work. I just found this issue - wasn‘t aware it already is in the pipeline.
