Forum breadcrumbs - You are here:Scenic ForumUsing ScenicTime Between Stops
Time Between Stops
Still loving the app. I tried searching these threads but didn't find an answer right away. I know how to pull up a list of distance and time between stops and via's, but is there a way to display the time and distance between just stops? For example, I may have a stop in my route for breakfast and then a second stop for lunch. There might by 6 via points between the two stops. I would like to see the total time and distance between just the breakfast stop and lunch spot instead of the having to see the individual time and distance between each stop and all the via's. That way I would know that between stop 1 and stop 2 there is a total of X time and Y distance without me having to manually add up all the time between via's. Does that make sense?
Thanks!
You can not see this during planning in the power planner (indeed vias are included there), but you can see the time/distance between stops during navigation itself by tapping the bottom bar where you see time and distance to destination.
Working on a big update for October where this will be visible in the power planner too.
Marts
