Thumbs Up / Down
Quote from Cecil on 24.05.2021, 08:32It would be a great feature to include a thumbs up / down icon on the nav screen. If the thumbs down is checked between two waypoints, Scenic never routes through there again, unless the mark is removed manually. Similar with thumbs up, Scenic always routes you through that section when possible. Perhaps this is an alternative fix to the dirt road issue. At least the app won't get you twice on the same road. 😉
Quote from Guido on 24.05.2021, 10:17I've had similar suggestions regarding the thumbs up / thumbs down, but more for marking a nice spot with a nice view / nice spot, etc. ( https://scenic.app/forum/topic/quick-location-marker-while-riding/ ) , not so much for marking nice or not-nice stretches. I like the idea as such, but not as a workaround for Scenic taking dirt roads when it shouldn't. That problem needs to be solved at the core (the bad map data), which will be done by Scenic 3 (uses better map data). Once Scenic 3 is out we can revisit if this feature is still requested and if so, what the priority of such a feature would be.
