The route is not being completed in Scenic
Quote from andretti2025 on 12.05.2025, 21:43My problem is the following:
I have carefully created 65 via points, and we plan to have lunch at point 30. So we still have 35 to go. Scenic is still active. After lunch, however, it takes the fastest route to the final destination. So it doesn’t complete the entire route.What am I doing wrong?
Thanks. André
Thanks. André
Quote from Dae on 13.05.2025, 00:37What are your detour settings? It’s possible that as you’re at lunch scenic recalculates, and after a few recalculations it will use your detour settings. If your settings are “guide me to the first unreached stop” your intermediate vias will be skipped.
You can also pause the route whilst having lunch to try and help
Quote from johansw on 13.05.2025, 02:03Personally, I use the Don’t recalculate button. Thereby, I get recalculate button on the screen whenever I am of course, look at the map for what is going on, and then press rec calculate, having full control.
