Terrible google URL import issues
Quote from VeganKnight on 01.06.2023, 15:50Hi everyone,
I believe it was at least a year or so ago. I really wanted to love this app but everything I built on Google maps would not employed with URL as expected I am picking scenic roads, and roads, but when I pulled out into the app, it still gives me to my destination, but completely some other way. There’s just so much to fix, I don’t even know if it’s worth trying to import from Google Maps via URL. Am I doing something wrong? Is there any trick to this? How are you guys building your rides?
Hi everyone,
Quote from Guido on 01.06.2023, 15:52I have made some changes recently that should improve the import. Are you still having problems now? If so, could you paste an URL here and a screenshot of how the route imports into Scenic?
Quote from VeganKnight on 02.06.2023, 13:46Thank you Guido.
Yep, still having problems. I was just getting started again to test so I haven't even done much. It's just a route between two points that does not import as expected.
Google URL: https://www.google.com/maps/dir/EagleRider+Motorcycle+Rentals+and+Tours+Denver,+4710+Lipan+St,+Denver,+CO+80211/Nederland,+CO/@39.8701466,-105.4145713,11z/data=!4m15!4m14!1m5!1m1!1s0x876c78df0ad75ee3:0x96b9be50064f953c!2m2!1d-105.0014129!2d39.7826862!1m5!1m1!1s0x876bc6c44e45525b:0x8d645c98aaec4cb2!2m2!1d-105.5108312!2d39.9613759!3e0!5i1?entry=ttu
Google Screenshot:
https://share.getcloudapp.com/nOuLB7pYScenic Import:
https://share.getcloudapp.com/6quJ7oDE
FYI after I create the route, I'm picking the one on Google Map, I'd like to use.
Thank you Guido.
Quote from Guido on 02.06.2023, 13:53Ok. Scenic is picking the first route option that Google suggests. And not the alternative route Google Maps suggested and you picked. Let me see if I can also get that scenario in the import.
Apart from that, I see the Scenic route is exactly the same as the primary route that Google suggests between those locations.
For now, as a workaround, don’t select the alternative route, but in stead, in Google Maps, drag the original route so that it becomes the alternative route you want. That will add a coordinate to the Google Maps URL and Scenic will use that as well.
Quote from VeganKnight on 02.06.2023, 14:09Got it, let me try that, thank you!
