Strict filter public routes
Quote from Nasty on 05.06.2022, 14:01Hello guido, big fan of scenic. Been using it for 2 years now. Big thumbs up!!
i took me a while (and a help of this forum) do find the public routes again. But one thing really bugs me to be honest:
* select the map to find routes: “1200 routes found. Add filters to take it back to 50”
* add filter 3 stars: “135 routes found. Add filters to take it back to 50”
* make selection map smaller: “85 routes found. Add filters to take it back to 50”
* add filter 4 stars: 75 routes found. Add filters to take it back to 50”
* add filter number of reviews 2: 0 routes found.” 🤣
i just try to say that the filter is very hard to use. Is it possibe to show more routes than just 50? Because if you use too much filters, you end up with almost nothing. At least for our belgian country.
thank you 👍🏻
thank you 👍🏻
Quote from Guido on 06.06.2022, 14:55I know what you mean. There is a technical reason for this. Sending a lot of routes (the routes in the search results) with all their coordinates, takes quite a long time. That's why I added the limit of 50. Additionally, I also had the idea that one would not want to scroll through a list of 100 or maybe more routes.
Let me give this some more thought to come up with a better solution for this that also performs acceptable.
Quote from RumHam on 20.08.2022, 22:37My second post here is also about public routes now that I know about them. I agree it is a bit hard to use the routes filtering. It's too bad it can't be higher.
