Street View or Look Around
Hi Guido
Just a quick question as to why, when in planning mode, if you long press on a location you sometimes get an option to "Look Around" and at other times the option is "Street View"?  It's not a problem either way, just puzzled.
Also, many thanks for the hard work you have put in since being let down badly by the previous map provider.
Charlie
Hi Charlie,
Lookaround is a built in component from Apple and provides a nicer user experience (you are not leaving Scenic). So, if lookaround is available at the spot you tapped, you get that option. If not, it falls back to Google Streetview (opens your browser).
Thanks for the kind words.
LaszloK and Charlie J have reacted to this post.
LaszloKCharlie J
