Forum breadcrumbs - You are here:Scenic ForumUsing Scenicstrange routing
strange routing
I tried a routing today but had to fill gas first and the gasstation was not on my tour (just 500m off) and therefore I used a different way out off the village. On the way out I pressed re-calculate the route and I ended up in a completely in a different (because shorter) way. No problem so far because that is normal, however than being back on my original route, I pressed again re-calculate and from that point it tried to bring me back on my route which was created after the gas station and now way to bring it back on a shorter way. Even close to my endstop scenic wanted me to turn around and go back to the first via point after the gas station.
Does anyone know that behaviour? Did I do something worng or why did Scenic insist on bringing me back to the first via point although I only hat a final target with no via points originally.
Thomas
Hi Thomas,
At the beginning of October, a very big update will be released, Scenic 4, with new detour behaviour. I believe this will resolve this issue and other reasons for misunderstanding and/or unexpected reroutings.
Middelfrangge has reacted to this post.
Middelfrangge
