Forum breadcrumbs - You are here:Scenic ForumUsing ScenicStops
Stops
Is there a setting that would audibly tell you that you are approaching, and have reached a Stop?
It does that by default, but only 50 meters before you reach the stop. This is a limitation of the HERE framework. I can not change this at the moment, but will have another look at this while I'm migrating to the new HERE map framework during fall/winter.
Visually / on screen you can get hints about an upcoming stop earlier. Have a look here for this: https://scenic.app/forum/topic/stop-in-route-text/#postid-4189
