Stop navigating when stop-point reached
Quote from Infos on 10.04.2023, 12:12Hi Guido,
Assuming I am using the app correctly, I did not find a way to automatically stop the navigation when reaching a stop-point.
The problem I have is that if on the map I have like 3 stop points, when reaching point 1, 2 or 3, the app will not notify me so and simply continue giving indications to the next point (any point, not only stop), and I simply get confused thinking I am still navigating to that point (when I am already beyond it).
So, is there a way currently to set a navigation stop when stop-point attained?
Or would it be possible in the future to set a default behavior or a message with a button informing stop-point reached and what do do now?
Quote from Guido on 10.04.2023, 12:44There is no way to stop the navigation automatically. However you do get notifications when getting close to a stop. It’s mentioned as part of the navigation instructions (top left corner), also a bar will appear at the top of the screen ‘reaches stop X’ and you will get an audio notification.
Here’s more info on the difference between via points and stops: https://scenic.app/help/stops-vs-via-points-whats-the-difference/
Quote from Guido on 10.04.2023, 12:53Forgot to mention… After you’ve reached a stop you can manually pause the navigation by tapping the bottom bar (where you see ETA) and then tap the pause button in the panel that slides up.
Quote from Infos on 10.04.2023, 12:58Will give it a try.
Again, I guess that when concentrating on the driving I don't pay attention to this stuff.
Cheers
Will give it a try.
Cheers
