Stats data is completely empty
Quote from Skdibi on 08.08.2023, 11:10I have been using scenic for a few months now, but the stats data is completely empty. Why is that and how can I fix it? Also, is this data recorded when I follow a track, when I record a route, or even if the app is active without using either of the previous two functions?
Quote from Guido on 08.08.2023, 11:14The stats data shows data from the rides that you saved. If you discard (don't save) a ride, it won't show up in stats. If you delete a ride it will be removed from the stats.
I'm planning to change this in the future so that even if you don't save a ride, or you delete a ride, the stats will be preserved. For the moment, however, the situation is as described.
The app starts recording as soon as you tap the 'start ride' (or 'start navigation') button. And ends recording as soon as you finish the ride.
Quote from Skdibi on 09.08.2023, 06:21Hi Guido,
I hope that with the next update even if you don't save a run or delete it, the statistics will be kept because it would be very useful.
Thank you!
Thank you!
