Some Way to Avoid Citys
Hi!
If possible i would opt. for the possibility in some way to avoid city centers trough out the route.
Could some of these idea´s work.
*Based on city avoidance.
* Avoidance based on streets with low speeds ( Example: 0 km/h - 50 km/h).
* Get Scenic to prioritize routing based on a preferred speed for example 70 km/h
Many thanks otherwise for an great app.
Regards Claes
Working on a big update for October. With that update it becomes technically possible to do this, although it will be a little while before I have time to implement this.
Hi Clubhan.
While using the powerplanner you avoid cities with just 2 waypoints.
Give a try until Guido finished his big update in autumn.
Ride safe, Mex
Excellent news Guido and a good work around idea Mex.
Regards Claes
Quote from Mex on 14.08.2024, 13:24
Hi Mex
Could you explain or give me an example of what you mean by this?
Paul
Hi Paul.
We been to Monaco, came back wednesday. My friend used Calimoto and it wanted to route us into the center of Muhlhouse France.
In the morning i used the powerplanner, planned the same route but avoided cities. Passing cities is mostly boring and takes too much time.
The picture is just an example how you set vias to deviate cities/centers.
As said: just an example.
Regards, Mex
