some minor observations / suggestions
Hi Guido, hi all,
first, my very best congrats to Guido for having lifted Scenic to the next level with all the hazzle of having had to change map provider and so on!
Scenic is becoming my go-to app for all kinds of navigation purposes, not only bike riding but increasingly including hiking and cycling adventures (I see a huge potenital there) or just checking location with a city trip. I really very much appreciate the new map style, costumization options and in particular the level of detail and up-to-date accuracy is stunning.
While I'm using Scenic during navigation, my workflow often involves other applications for route planning. To be honest, I often use 'Kurviger' or 'Calimoto' to plan a motorcycle ride, export it as .gpx and import the ride into Scenic as I find Scenic's user interface, accuracy of the GPS position (in particular latency I found to be superior with Scenic) to be much better for my taste. I found the Scenic options for motorcycle riding a little bit limited but things might change when the beauty routing becomes available in Europe (is there a date yet?).
Recently, I've chosen the same approach for bike cycling and hiking, importing routes from apps like Komoot or Osmand. And it works quite nicely and as said before, I do like Scenic's map style, responsiveness of the app etc. much better as compared to these alternatives. I always export as tracks and insert additional via points as necessary (works great btw).
What could be improved here are the following issues:
  • when importing a route, it uses the 'automobile standard' option for generating the route/connecting the via points in Scenic. Maybe it would be better to use the latest chosen routing style (e.g. curvy motorcycle routes)
  • when planning a hiking route, I cannot insert via points on hiking trails (something that makes probably sense for motorcycle riding :)). Maybe you can allow insertion of via points for hiking trails (or depending on the routing style allow insertion of via points on hiking trails when in bicycle or hiking mode)
  • When route planning, I use the add via button to automatically insert an additional via point. This often works flawlessly regarding the via position and # but sometimes the chosen # of the inserted via is plain wrong. Maybe an option can be implemented to select the # of the via that is to be inserted?
  • during motorcycle navigation, I use a Zoom of 9.5 point in the velocity range of 70 - 110 km/h. This is because I would like to see the names of the next villages and sourrinding sites. However, it often happens, that the actual names of towns / villages are not showing up on the map or show up briefly and disappear again when e.g. road direction is changing (but other, to me minor important information such as parking areas, restaurants, tiny little farm names etc. appear). Maybe there is an option to prioritize showing of city/town/village names over other information?
  • While it is possible to change the font size of cities / countries / bigger towns in the map customizer, this does not have any effect (i.e. changing their font sizes does not work). Maybe just a minor bug that needs fixation.
Anyway, these are some minor points and if time allows, would be great if these could be addressed within a next release. As said above, I think Scenic has a great potential for navigation purposes outside motorcycle riding.
Thanks again for your hard work!
Kind regards,
Werner
Hi Werner,
Thank you for your feedback and your suggestions. I'm happy that Scenic is working well for you. Here some responses from me:
..options for motorcycle riding a little bit limited but things might change when the beauty routing becomes available in Europe (is there a date yet?).
There is no date yet, sorry. I'm working on increasing the routing options for motorcycle riding. For both these things I am dependent on 3rd party provider though, so not entirely in my control.
I could implement that. Or ask the user what vehicle to choose. I'll add it to the list.
Could you perhaps give me an example of such a trail where Scenic is not letting you add a via point? (A GPS coordinate of that trail)? I'm asking because it should let you add a via point if that trail is marked as accessible for hiking / biking respectively. It might be a map error, but would have to see an example.
This already exists. If you long-press the via # or stop # button Scenic will let you choose the via point after which the new via point should go.
There is. Let me look into that.
I can not reproduce this. It works when I change the font size for these labels. Could you double check? If you can't get it to work, could you share the ID of your custom map style? (see here how: https://scenic.app/forum/topic/scenic-4-custom-map-styles/#postid-12240)
Thanks a lot for your quick response!
Here some additional information:
--> understood, thanks for letting us know!
--> excellent, thank you!
--> here is an example: it seems via points can be inserted (something I seem to have missed last time) but the routing is transferred to the nearest accessible road; unfortunately, I didn't find a way how to download the gps coordinates but if you tell me how to do that in Scenic, I can certainly let you know the coordinates
--> this is great info! I didn't notice that
--> here is the ID of the map style I am using (in fact it is a map style created by another user which I finetuned for my needs). I just checked again, and I cannot change the font size for anything bigger than a small town (changing font size for anything bigger than 'Ort' will not have any effect).
10A52B26-2A50-4C52-AB8D-2CEF7C5D3951_8D355312-EB98-41DB-A4A1-7FB05805AE69
In any case, thank you very much for all the efforts you put into this!
Thanks for the additional info. I’ll look into it in the coming week. To get a GOS coordinate in Scenic, tap on a waypoint or long-press the map. Then, on the callout bubble that appears, choose “copy coordinates” and send me the DEC coordinates.
Ok, good to know, here are the coordinates, should roughly correspond to the screenshot above:
47.866285,8.273804
47°51'58"N 8°16'25"E
