Skipping the start point not possible
on a trip the last three weeks, I had the problem(I used Carplay), that when I not exactly reached the starting point or not starting from the starting point, the starting point was not skipped automatically. This leads into the situation, that "Scenic" recalculates the route always back to the starting point. The result, the distance to destination gets longer and longer.
Skipping the waypoint manually does not work either and because we were riding in a group I can't stop to solve the problem.
Is there a way to skip the starting point automatically?
Marc-Antón
Hi Marc-Antón.
It's strange that manually skipping the waypoint did not work. Were you already getting navigation instructions when you tried this? I'm asking because, if, for example, you start the route on CarPlay, and, assuming you answered "yes" in the below alert... it's still possible (for example when you are inside) that navigation instructions don't start until you reach the magenta line. Only then does Scenic know what the next waypoint is. If you are not on the magenta line yet (and you are not getting navigaton instructions) then Scenic does not know what the next waypoint is, and so it can not skip it.
There is no way to skip the start point automatically, but you could choose "no" in the above alert. Then, navigation will not start until you reach the route. It doesn't matter where you reach the route. If you reach it "behind" the route start, it will mark the route start as reached.
Thanks Guido.
I understand.
I had the following situation, I planned a route in my hotel room and took as starting point my current position.
When I went to my motorcycle in the morning and loaded the planned route, I answered the above question with "no", because I was on the route. When I started driving I was on the magenta line, but I hadn't reached the starting point because it was in the hotel room and "SCENIC" tried the whole time to route me to the starting point, which I would never reach. Skipping the waypoint did not work, I pressed it several times, but no luck.
So perhaps I had to answer the "Do you want to be guided to the route start?"-question, with "yes"?
In the future I will set the starting point to my motorcycle.
Marc-Antón
Or even better - as I normally do to avoid inaccuracies of the gps position - set the starting point a bit down the road you plan to go.. 😊
Hi Marc-Anton,
I believe this is actually a bug. When you choose “no” it should pick up the route from wherever you join it, and mark all waypoints before that as “reached” (including the route start).
I’ll look into it.
Johan’s tip is also a good one. I always put my route start further down the road or even a general point like a gas station (in case I want to make that route public or share it with others).
Karimero has reacted to this post.
Karimero
