skip via point button size
Quote from Hoya95 on 22.10.2024, 10:28Do others have problems hitting the trashcan icon to skip a via point? When I'm trying to skip a via point, it usually is an exercise of mashing the screen and hoping for the best; usually takes me 2-3 tries minimum and I usually end up having other menus popping up on the screen accidentally, which I then have to dismiss. Somewhat dangerous while riding.
I'd love to let Scenic "just figure it out" and skip the via point but I haven't found a setting to my liking despite the numerous settings available; many times, manually just telling Scenic to skip immediately is highly preferable to all the recalculating, etc.
I guess I should have posted this under feature request - but a much bigger "Skip" button that is not right next to any other "action" elements on the screen would be highly welcome.
Quote from Guido on 22.10.2024, 11:13OK. I'll see if I can make it a bit bigger while still leaving enough room for the map on the smaller devices too.
For what it's worth... you can tap anywhere on this button... not just the orange part where the trash can is at, but also the white area (or black if in dark mode) to the right of the trash can.
Quote from Hoya95 on 22.10.2024, 12:13
Hi Guido, I should have added - on one of my bikes I ride w/the phone in landscape mode. It is definitely in that configuration where I have the most difficulty and end up hitting the menu buttons accidentally.
But it is good to know that I can tap anywhere (including the flag icon) and not just the trashcan; that may help quite a bit.
