Show track while navigating?
When importing from Kurviger, both track an route is used and Scenic then creates its own route.
Is there a way to keep track as an underlying "truth" (i.e. the actual intended route) and show this under the Scenic route when navigating? Kindof like a backup of what was intended, incase Scenic does something bad...
During import you can see the track as a blue line. This is to help you make any adjustments to get the magenta (calculated) line match the blue line. So, at that point, you know the route is the same as designed.
Then, if you want, you can turn on ‘show original route’ (Settings > Navigation & Tracking). This will show you that route even if you deviate from it.
dasherpr has reacted to this post.
dasherpr
